How to …
BioCAT supports a number of techniques for analysis of partially-ordered and disordered biological materials. Below is a list of HOWTO documents for experiments at the BioCAT facility. These are intended both for new users as they design their experiments and for users at the beamlines as they run their experiments.
These descriptions should help you to decide if our facility can support your research. However, it is strongly recommended that—-prior to visiting BioCAT—- you discuss your experiment with the User Liaison for your technique after reading these descriptions. In this way, your experiment can be tailored to our facility so that you spend less time assembling and debugging your set-up and more time taking high-quality data.
Small- and Wide-Angle Fiber-Diffraction (includes muscle diffraction)
